Blaired79
Ah. Okay. So what mm lens are you using according to that table?
Also, try going into Main Camera settings and change focal length to 0. Then go to Preview Mode, take a single exposure, then tap on plate solve to see if it works. If it does make at to tap on Sync if it succeeds.
The ASIAIR will then set the main camera focal length and use what it sets.
Also - did you read this: https://www.yuque.com/zwopkb/asiair/dslr-ml-connections
Peter Zelinka did a video on connecting a DSLR to the ASIAIR without a telescope. Worth watching:
https://youtu.be/zfrFhOtoBxo?si=a2ceST1ZgyYgt-CC
Also, as an aside, if you're powering the mount from the power outlet on the ASIAIR, ZWO don't recommend it.
https://www.yuque.com/zwopkb/air_plus/aufptq
