Hello.
I was trying to capture comet C/2023 A3 (Tsuchinshan-ATLAS) a few days ago, only 3 very faint stars appeared in the field of view (in preview mode), and the Seestar application did not take any valid initial capture, and consequently any stacking, as there is no option to save the captures regardless of whether they are considered good by the application.
This together with other possible uses of the Seestar, such as the measurement of variable stars, which require the greatest possible calibration, including taking flat frames, which due to the way the application captures would be impossible to do.
For this reason, I would find it interesting to have the option to save all the shots from a capture session, even if the Seestar does not find stars to stack the shots, or considers that a shot is not good.
I hope you can take this into consideration, as it would significantly expand the uses of the Seestar S50.
