I am having problems getting my new ASIAIR Plus 256Gb to work correctly with my Nikon D700.
I have tried a different mobile phone and another shutter cable and I still have problems.
This what I have found:-
a) If I disconnect the 10 pin shutter cable and turn OFF "EXP with shutter release cable" I can then use 0.001 secs in preview. I can also use 0.000125 secs (1/8000 sec) in Autorun without any problems.
BUT
b) With the 10 pin shutter cable connected and "EXP with shutter cable" turned ON, I get intermittent failures in preview. When I try to use autorun with 5 shots at 0.000125 (1/8000 sec) I get "exposure failure" after 2 or 3 shots.
I have also connected an external intervalometer to the 10 pin port on the D700 and I can shoot at 0.000125 secs (1/8000 sec) without any problem. This makes me think the 10 pin port on the D700 is OK.
My conclusion:-
Either there is a problem with the ASIAIR plus or there is a problem with the ASIAIR android software??? I am running Android version 14 on my Samsung Galaxy A52 5G. I am running 2.2.2 11.30 on the ASIAIR plus. Has anyone else got a Nikon D700 that has got similar problems or has any advice for me.
