PMTeam@ZWO I have uploaded logs every time it has happened.
It has to be a software issue...
As you will see I have sent logs and screenshots. I have not seen the issue of where ASIAIr gets stuck on loading for several days, but the corrupted image appeared again last night. Once that happens I have to reboot the camera, which is, of course, a big pain. It means I can't do an automated run overnight, because when the corrupted image happens every image after will be corrupted. As I said, rebooting camera fixes it. Seems like a memory leak. It never happens early in a session, but when camera has been running for awhile. Hope this info helps.
