Hello The filter doesn't work I choose west direction and the filter shows me M31, actually at east part of the sky
Is it possible to fix this? Maybe i am doing something wrong
Thanks
satch984 The problem should has been fixed in V2.1, do you install the newest 2.1 version? If so, could you also take a pic of M31 information? thanks.
I already reported this about a month ago. Unfortenatly they have not fixed it with the latest update. :-(
Tech@ZWO
Here it is The filter doesn't work well
I will retest as soon as the weather gets better.
xfirf unfortunately not
satch984 The filter recommended only works in Stargazing mode, so if you enter the target in the sky atlas, need the user to turn on manually, we will optimize it in the future.
I am experiencing this same issue. My best part of the sky is occluded by a giant tree and the house. I am in stargazing mode and all of the "Tonights best" are in the portion of the sky I can't see. I also have the latest version of the ap. Thank you
Cringle Since the recommended targets are currently in the part of the sky that's blocked, we suggest either moving the telescope to a more open area or manually selecting a different target that's visible from your location.
