Tech@ZWO A lot of people complain about this Sun and Moon finding issue since the new firmware.
I have to find the Sun manually, because Seestar always aims above the Sun about 1-1,5 degree during the finding process. I have a granite table at work, it is perfectly leveled, because of the high precision work we do. The quality guys check it every week. I did the level calibraton of my Seestar on this granite table, so it can't be a level issue. I did the compass calibration in the field, at least 30 meters from every iron or other metal things. I checked it with a classic compass and it looked good. I adjusted my Seestar with 0,2 degrees level issue, hit Goto Sun, and aimed over the Sun about 1,5 degrees while finding it. I saw the brightness of the Sun at the bottom of the field of view, when automaticly slew to find, but never found it. Then I switched Seestar off and back on, adjusted the tripod level with 1,5 degree issue to aim a bit below the Sun. When I looked at my Seestar, it was clearly seen it was not leveled and leaned towards to the Sun. Hit Goto Sun and found it immediately!
As you can see this should be something else, not a calibration issue.
