I was doing a mosaic of the North America Nebula. Est time was a little over 1 hour. At 54 minutes it started failing. Everything was fine. Scope, sky etc. Stopped the mosaic and then tried again without Mosiac and it was capturing fine. Any idea what would cause this?
Getting this on everything I try. stack failed image discarded. If I image without mosaic mode I can image for hours. With Mosaic I get 8-15 minutes and the stack failed image discarded error starts appearing.
bkushner I had this with M31 after some 700 lights taken. Suddenly every new image faild to stack without any visable reason.
Brille Yeah it's happening to me on everything I try. North American, California, M31, etc. Last night M31 4 hours and I got 1 hour of data. Clear skies and no other issue. Wonder if company knows of this issue and if there are any solutions.
bkushner
Brille Could you please submit a bug report when the problem appear next time? thank you. https://h5.seestar.com/course/79221
Tech@ZWO I've sent my logs now what do I do?
Ich habe diesen Fehler auch nur kommt noch ein anderer Fehler hinzu. Das Ergebnis des autostack.fit hat einen Fehler in der Bittiefe und wird in Siril und anderen Applikationen mit einem Muster angezeigt. Dieser Fehler betrifft aber nur den Mosaic Stack nicht aber den Stack aus den einzelnen Fit Dateien die mit Siril oder PI weiterverarbeitet werden.
bkushner What is your BT number? we will analyze it and get back to you soon, thank you.
Tech@ZWO Would help if I knew what BT meant
bkushner You can find the BT number here.
20241107716123s
bkushner Thanks, we found some problem and will optimize it in the next version.
