Many users have a couple of different telescopes/mounts. If we switch between setups, we have to manually enter in all the telescope, mount, equipment details and all of their respective settings. for example, I switch between an SCT and small refractor, which requires me to change nearly every setting each time I do so.
Having the ability to select between different equipment profiles with all of the settings saved for each setup would be invaluable.
    Write a Reply...
