ASI2600MM Pro refuses to change to temperature lower than 0 deg C. I tried to manually set the temperature by selecting -10 deg C button or manually inputting "-10" on ASIAIR but both refused to set.
The sensor temperature reads 0 deg C and the cooler capacity is running at around 20% (while ambient temperature is around 15 deg C)
Is it the software problem or the hardware problem?
