A weird thing happened last night. I went to my target after setting up guiding and the Autofocus did not start before capture started. This was the first time that has happened. I checked to make sure "AF before target" was on and it was. Any ideas on what is going on?
    JTSAN Hello. What is your software system and phone version? Could you please submit the bug report and related screenshots? Our developers will find the cause based on the log. The premise is that your ASIAIR was not turned off after the problem occurred.
    I am on an iPhone 12 on iOS 18.1.1. I did not turn off the ASIAIR after it failed to start a focus before starting to capture a target. In addition, the correct tab was selected to make sure it did try to focus. having said all this, I have captured three other images since this issue first started and all three went to autofocus before capture. I assume the issue was an anomaly, but if it happens again, I will send the log file to your developers. Thank you for your concern.
    Cheers,
    John
      5 days later
      JTSAN but if it happens again, I will send the log file to your developers. Thank you for your concern.
      Thanks for your help.
      Write a Reply...
