Gulyas K "So a 19 minutes mosaic is actually a barely 8 minutes long full exposure."
It's not even that much. For 1.5x diagonal framing, at 19 minutes total exposure it's usually just barely visually finishing up the last corner on its first pass, with only 2 exposures (20 seconds) in that corner, and still needs to make more exposures centered on the edges of the frame itself to clean up those noisy corners. To actually complete the full single pass it'll take another several minutes.. say.. 25 total, give or take. If you jump back and forth between live view and the Sky Atlas you can see that it spends a fair bit of time taking exposures that are literally half outside the frame which means 1.5x is really more like 1.5x + .5 + .5 or 2.5x total. Given all the the time it takes to take two exposures, then move, and sometimes discard frames with star trails while it's recovering from gear lash, I've generally found I need around 3 real hours to get 3 full passes, with about 75 minutes of total exposure time. Better still if you can get it up to 90 or 100 minutes of exposure.
