What is the distance from the inside surface of the Protect Window to the sensor surface? If there is an additional glass cover for the sensor itself, what is its thickness? Thank you.
coconuts The distance from the sensor to protective window is around 8.1mm, the additional glass cover thickness is less than 1mm.
Do you have an anti-reflect coating on this window ? Thank you.
mspinnato Yes, it is AR version.
