I'm having major problems with my Baader MPCC MKIII in connection with ZWO EFW, Optolong L-Ultimate and ASI2600MC Pro on my Skywatcher 200PDS.
Camera is connected to EFW with filter, then there is a spacer and MPCC that slides in the focuser.
Pics with all other filters calibrate just fine but with the L-Ultimate between the camera and MPCC, there is a horrible
ring that will not disappear using calibration frames. The flats have a bright very clear ring on them when using MPCC but the ring goes away immediately after removing the MPCC. The ring also disappears when I move the filter in front of the MPCC. Below are two pics on what it looks like with and without the ring (no flats but just 2s shot on a white wall to test).
Filter in front of MPCC:
Filter between MPCC and Camera:
This causes naturally all stacked pics to have the same ring visible but only on green and blue channels, not on red.
I found some discussions online saying that older MKII versions of the MPCC had problems with internal reflections when used with narrowband filters. They said that the problem either disappeared or significantly reduced when they moved to MKIII but since I have the MKIII already, there is no room for improvement there.
The strangest part in all of this is that I never had any problems when I was using ASI071MC Pro but now with the 2600MC Pro the problem has appeared. I don't have the ASI071MC Pro anymore so I can't test it unfortunately.
Have you heard of this kind of a problem earlier and would you have any solutions? Could it be that my MPCC is MKII and MKIII could solve the problem? If not, do you have any suggestions on a coma corrector I could perhaps use instead of MPCC?
