  • Which wavelength range does the IRCUT filter cover?
This would be important because the LP filter is placed on top of it and I would need the exact parameters to calculate the SPCC.
There are also IRCUT filters that extend into the visible range and thus influence the values ​​of the LP filter.
As far as I've been told, the Seestar (S50) toggles between UV/IR-cut and LP.
And the UV/IR-cut has a bandpass from ~ 400nm to ~ 700nm
The LP-Filter should have these characteristics
Thanks, but that wasn't the question. The Seestar also inserts the LP filter.
The IRCUT is always in use and therefore the question is whether the IRCUT filter extends into the visible area. There are IRCUT filters on the market that have this property and then I would have to take this into account in the calculation for an SPCC.
    fedorauser You do not need to manually account for the IRCUT filter in the SPCC process within PixInsight or Siril, because the filter's effect on the color channels is already baked into the data you’ve captured.
    I'm not sure about the workflow in the forums, after all this is third party software.
    Sorry, but that can't be true, because the same would then also apply to the LP or any other camera and filter combination.
    The simple question is easy to answer: what area does the IRCUT filter cover?
    There has to be a chart for that as well as the LP filter.
    Is it the original filter from Sony or is it an in-house development?
      Support@Seestar Dieser Filter ist unser eigener und der Abdeckungsbereich ist in der Lage, Seestar vollständig abzudecken.
      Sorry, that wasn't the question. I'm looking for the chart that, like that of the LP filter, tells you which wavelength it is active on.
      As an example, a Noname IRCUT filter
      or also seen here.
      https://www.zwoastro.com/product/ircut-filters/
      Therefore, this diagram would be necessary for an accurate calculation of the SPCC.
      Thank you for your effort
      5 days later
      I would like to bring up the topic again and not get on any of the developers' nerves.
      I need the diagram for the IRCUT filter to correctly calculate a spectroscopic color calibration (SPCC)
      Thank you
        fedorauser
        UV/IR Cut filter: Filters out ultraviolet and infrared rays and only allows visible light to pass through. The spectral curve is as follows:
        Thank you for the diagram. This means that the filter extends into the visible range and must be included in the SPCC
        Violett: ≈ 380 - 420 nm
        Blau: ≈ 420 - 490 nm
        Grün: ≈ 490 - 575 nm
        Gelb: ≈ 575 - 585 nm
        Orange: ≈ 585 - 650 nm
        Rot: ≈ 650 - 780 nm
          fedorauser
          Alright, I have to admit my mistake. I haven’t used this third-party software before, but I would be happy to help you if I can.
          Write a Reply...
