So my firmware is currently 3.2.3.
I tried the updating tool run with Admin permissions under WIndows 10 Pro - with the device powered by first a USB2 cable plugged directly into a powered USB 2 / 3 hub - first trying a powered USB2 port and second attempt trying a powered USB 3 port - and then I tried a seperate higher power USB3.1 powered port on another high speed hub.
In all threes attempts the Update program listed found teh device and the firmware - but failed immediately once the current firmware was selected - with the error message "failure to erase firmware".
So 1) what causes a failure to erase firmware error and 2) what can be done to resolve my problem with your EAF?
