  • Custom objects using J2000.0 coordinates
Gulyas K Agreed. Its rather ridiculous to make those "its easy" statements. Its getting quite tiresome.....add to that is whether a monetary profit can be made from "the easy" changes......
Gulyas K You are correct, I am a retired hardware design engineer with 40 years of experience, so I cannot claim to have software development experience. If you need help with your FPGAs, I am your man. Which is probably why I am impressed by the S50 and so disappointed by the SeeStar app. In the job I just retired from, the customer was king. If they asked us to bend backwards, we would ask how far. Not your usual sedate software development flow.
Some of the things I am asking for seem really easy to do, some not so much. I don't know, get a co-op student and let them try to solve such small requests. If the solution works, incorporate it into the main code branch. If it doesn't, no harm done. ZWO seems to have a very rigid and slow software development. It looks like it's driven by engineering and that's not right. I know, because I am an engineer. ZWO needs to hire a competent inbound marketing person and have them drive the entire process.
I am no spring chicken and I cannot wait years for requests to go through a glacial software development process. I waited for 9 months for a mosaic feature and we finally got it, it is next to useless. Maybe you still have most of your life ahead of you, I don't.
    Support@Seestar yes I know we can enter coordinates using Jnow epoch but it would be much easier if we had the option to enter J2000 epoch coordinates for custom objects since those are the coordinates typically published in object catalogs.
      jNow and j2000 are not the same coordinate format?
      I've been using j2000 coords for manually inputting comets that aren't in the S50 comet database.
        sthscan the format is the same but the values will be slightly different due to the precession of the Earth’s poles. The change in coordinate values from 25 years ago (J2000) to now (J2025) for custom objects may make enough of a difference that your object won’t be centered in your image. I use SkySafari to find Jnow coordinates (currently showing as J2025) for inputting my custom object coordinates but it would be so much simpler to use J2000 as you’ve been doing since that’s the usual epoch you’ll see in most catalogs or online sources of coordinates for things like comets. Hoping ZWO implements my suggestion so you can pick which epoch your coordinates are tied to. Hope that helps!
          sthscan Like the names imply, they are two different things. Jnow are RA/Dec coordinates based on the current position of the Earth's axis, J2000 coordinates are based on where the North Pole was 25 years ago. Both are useful, Jnow for precisely pointing to a target right now, J2000 as a common reference for images of the same object taken at different times. There is a difference of about 8 arc minutes between the two right now.
          I have no problem with entering coordinates into Custom. But for some entries I fat fingered the RA and DEC and cannot see how to delete or edit them. Is it possible to edit or delete Custom entered objects?
            You cannot edit an entry, that would be too useful. You have to delete it (swipe it left, which is not obvious) and re-enter it.
            Chiefland go to "My favorires" "customize" swipe from right to left to get the delete symbol.
            7 days later
            LA3QMA THANK YOU! I would have never found this and greatly appreciate you providing me with the answer I was hoping to find.
            Write a Reply...
