Hi everyone,
I have an ASI1600MM-cool that I noticed doesn't seem to be cooling or seems to be cooling intermittently. I use SGP to capture and when I turn the cooler on, the output % will slowly ramp up to 100% but the temperature never reaches the setpoint of -15c. It's about -4c out right now so I know it's not an ambient temp issue. I did swap out power supplies and bout a new 5 amp power supply and symptoms are the same.
I did pull a log from the camera after running the cooler and seeing no change. The only thing that stood out to me were a long string of bcooleron/bcooleroff commands. Does this mean anything in particular.
Anyone got any suggestions?
Thank you.
