Morning,
is is cool to take my S50 as carry on with British Airways, I am trying to find out the tech spec on the battery but not having much success , I need to know if it falls below if the battery falls within 100-160WH and has a lithium content of under 8g?
Any ideas?
    I have traveled with the S50 as cabin luggage many times without any issues. The battery is rated 6Ah, I would say it is definitely less than 100Wh. How can one tell what the lithium content is? People travel with laptops all the time and the S50 is not different. The questions you are asking could be an issue if you were to check the S50, but I would strongly recommend against that.
    amesy
    Here's what You can find on the original battery. It's 22.2 Wh.
    Write a Reply...
