Hi all,
I’d like to return to this thread with a quick update and a couple of suggestions following the release of ASIAIR v2.4 beta.
First of all — thanks to the ZWO team for finally addressing some key issues in this update. The ability to define a rotation range and improvements in coordinate handling are definitely steps in the right direction.
Now, to make the CAA truly practical for real-world use, I’d like to re-emphasize two critical improvements that are still missing:
Allow users to define a manual "home" or "park" position (ideally the mechanical zero or any user-defined angle) to be used at the end of a session or plan.
This feature would make a huge difference for those of us who need to:
Safely store the OTA after imaging, especially in tight enclosures or when the filter wheel extends downward.
Avoid collisions with dovetails or storage cases during automated shutdown.
Ensure predictable behavior when reinitializing the system after power cycles.
Suggested implementation:
Add a simple angle input box in the CAA settings menu to define the desired “home” or “park” angle (e.g. 0°, 90°, etc.), and a checkbox such as:
“Park CAA to defined angle after plan/preview/live mode ends”.
Add an option to disable automatic rotation after a GoTo.
Currently, ASIAIR automatically adjusts the rotation after every GoTo, even by a few degrees. This becomes extremely frustrating after taking flats — the tiny angle changes force you to retake all flats again, just because the CAA decided to apply a micro-adjustment.
To fix this, I propose:
Adding a setting in the CAA menu:
“Apply automatic rotation after GoTo” → [Enabled/Disabled]
Or, even better, prompt the user after each GoTo:
“Object located. Apply rotation to match framing?” → [Yes/No]
This gives control back to the user and avoids unnecessary image misalignment or flat frame repetition.
Once again, thank you for the continued improvements — the CAA hardware has real potential, and with a few more software updates, it could become a reliable part of the imaging train.
Clear skies,
igblaar
