L6m93p6d Hello. What software version are you using? We recommend that you do the following:
1 Long press Reset to reset Wifi
2 If method 1 does not solve the problem, it is recommended that you unplug the cable to turn off the power, wait for a while, and then re-power ASIAIR to see if the problem is solved.
