Hello ZWO community ! :-)
I sent a request to ZWO support but I also wanted your opinion
I had a surprising guiding problem last night.
On the ASIair's guiding interface, I could see very few stars, even at full gain (I try différent exposures too). (ie. Screen)
So I did a test by replacing the main camera with the guiding camera and with the gain at 90 I could see lots of stars... (i.e. Screen)
I tested the guidance camera alone (ASI174MM mini) and it works, I see lots of stars)
This is the first time I've had this type of issue.
Before this last update I had a normal display of stars with a gain of 90, and I didn't have any particular guidance problems so far.
A friend of mine told me that it was an ASIair bug that he'd also encountered and that I needed to reinstall the firmware, which I'm going to do this morning.
Note : just before starting my session, I got an ASIair update.
The seeing was good.
Do you know of such a bug?
My configuration:
C8 Edge HD + 0.7 reducer + OAG
Main caméra : ASI533MC pro
Guiding caméra : ASI174MM mini
Mount iOptron CEM40
ASIair last update
