Hi all,
I’d like to return to this thread with a quick update and a couple of suggestions following the release of ASIAIR v2.4 beta.
First of all — thanks to the ZWO team for finally addressing some key issues in this update. The ability to define a rotation range and improvements in coordinate handling are definitely steps in the right direction.
Now, to make the CAA truly practical for real-world use, I’d like to re-emphasize two critical improvements that are still missing:
- Allow users to define a manual "home" or "park" position (ideally the mechanical zero or any user-defined angle) to be used at the end of a session or plan.
This feature would make a huge difference for those of us who need to:
- Safely store the OTA after imaging, especially in tight enclosures or when the filter wheel extends downward.
- Avoid collisions with dovetails or storage cases during automated shutdown.
- Ensure predictable behavior when reinitializing the system after power cycles.
Suggested implementation:
Add a simple angle input box in the CAA settings menu to define the desired “home” or “park” angle (e.g. 0°, 90°, etc.), and a checkbox such as:
“Park CAA to defined angle after plan/preview/live mode ends”.
- Add an option to disable automatic rotation after a GoTo.
Currently, ASIAIR automatically adjusts the rotation after every GoTo, even by a few degrees. This becomes extremely frustrating after taking flats — the tiny angle changes force you to retake all flats again, just because the CAA decided to apply a micro-adjustment.
To fix this, I propose:
Adding a setting in the CAA menu:
“Apply automatic rotation after GoTo” → [Enabled/Disabled]
Or, even better, prompt the user after each GoTo:
“Object located. Apply rotation to match framing?” → [Yes/No]
This gives control back to the user and avoids unnecessary image misalignment or flat frame repetition.
Once again, thank you for the continued improvements — the CAA hardware has real potential, and with a few more software updates, it could become a reliable part of the imaging train.
Clear skies,
igblaar
