Used EQmode successfully the other night unit powered off due to battery drain overnighteven with backup which is ok. However went to use it again app shows CLOSE ARM, it is already closed. I’ve reset I’ve deleted app on ipad installed again, no change. If I use Scenery mode I can move it all around after opening arm manually with joystick it also moves up and down to limits properly. It also rotates on it’s axis as it should calibrated level sensor and compass still no change. Any one else have this issue ? Only once it closed with filter on by. Accident worked fine afterwards. I’m stumped!
