JohnK wrote:Hi everyone,
- Are people capturing using SER, AVI or BMP files?
Hi John.
You must use the formats of files that fits your job bedst.
-A AVI video may contain only frames with a color depth for of 8 bits per channel (RGB or b/w).
-A SER video may contain frames with a color depth for both 8 or 16 bits per channel (RGB or b/w).
-BMP Format can contain an image with a color depth for of 8 bits per channel (RGB or b/w).
-PNG, TIF or FIT format may contain an image with a color depth for of 8 or 16 bits per color channel (RGB or b/w).
It is not certain that the various programs available and use all the listed formats, so you have to choose from what the intended application can use. FIT is the image format normally used for DSO work.
Common to all the formats you use, they do not contain any destructive compression. In fact you do not normally compression for astrophotography.
For planets it commonly has only 8 bits of video (AVI)
For sun and moon max color depth the camera can deliver (SER).
And for DSO work color depth the camera can deliver (FIT).
Hope the above text can help you further.
Regards Leif.
