ASIMount-ZWO
Hello,
first of all, thank you for taking the time to address this feature request.
Regarding the current sync functionality: from what I’ve observed, it seems that only the last sync point is taken into account. For example, if I level the mount and point it roughly north, then perform a GoTo to Jupiter, adjust the position, and sync—it works fine. But if I then GoTo Vega, adjust and sync again, and later return to Jupiter, I have to manually adjust and sync it once more. The same happens if I go back to Vega—it has lost the previous correction.
It would be very helpful to implement a three-star alignment (or even better, an N-star pointing model), so the mount can refine its accuracy based on multiple sync points.
Additionally, it would be great to have a way to view a list of synced stars, with the option to add or remove individual sync points (e.g. in case one was poorly aligned).
This kind of feature would significantly improve the experience for visual observers and anyone not using a dedicated plate-solving workflow.
Thanks again for your support and for continuing to improve the mount's capabilities!
Best regards,
Paolo
