I am using an Askar SQA106, ASI 2600MC Duo on a TC40, PE200, CAA, EFW and EAF from my back garden paved with concrete slabs (no movement); anal about cable management and do my best polar alignment (usually below 10" for both DEC & RA) before setting off the Autorun in ASI Air Plus.
I have been happy with the AM5N since received last month with RMS total below 0.5 (RA below 40% Dec below 30% both @ 500ms and 0.5 Sideral), except that from couple of nights ago, when errors during RA guiding forced me to loose most of the subs taken due to star trails and drove me to increase RA to 85% in an effort to correct the deviations as quickly as possible. The strangest thing is last session (few days ago) was behaving properly and have not changed anything. There was no wind and no bumps with the rig as I was standing a couple of metres away.
I have read so many treads and responses suggesting to lower the time to below 100ms, below 30% aggressiveness and will try 0.25X sideral.
Update from last night 9 & 10Jul25
I tried the suggested settings above and also tried the setting of 100ms with RA between 30-50% and Dec 40-20% with 0.5 and 0.25 Sideral but the results were similar: RA excursions were outside the chart whilst Dec remains well behaved below 0.4”.
I went back to basics and had only connected the focuser and camera (CAA, and EFW) were still attached but no cables (power or data). Results were similar, continue to experience significant departures on the RA channel.
Also tried 2 different power supplies and a new USB cable between the mount and the ASI Air+ and also to the camera with the same results.
Clouds just rolled in and I am packing for the night… defeated.
I have added my mount chart, pictures of the excursions and ASI Air+ log for reference and have raised a ticket with ZWO but based on your posts should not be holding my breath...
