Hi,
I have an AM5 (also have Asiair+ connected to it), and I have only used for visual so far. I will find a target to look at, everything fine, mount tracks ok, etc. But then, without warning, the mount decides to randomly start moving. We're not talking a little bit - it more in fast slew mode, and it can end up as much as 180 degrees in the other direction before stopping. Doesn't happen always, but happens pretty frequently - at least a couple times a night.
Has anyone experienced this and, if so, did you figure out the issue?
Thanks very much
