curtismacc There is that, (and it's plenty annoying by itself), but I think there's more to it.
In my first session I started with it not levelled, got the offsets down to less than 0.4 on both axes, but had
persistent small star trails. So tonight (after waiting a week of cloudy skies), I intentionally started with it not levelled got the offsets, moved it until it showed 0.1 0.3, then immediately requested offsets again, and it said 3.2 and 2.7 off. (solid base, no wind.. etc)
Note: for the 2nd offset check it doesn't even move the scope. Centered it again to < .3, then requested offsets again and it stayed within range, and imaged without star trails. My hypothesis is that if it's not levelled first then adjusting for the first offsets when you've only got alt/az on the wedge aren't guaranteed to get the scope's rotation axis pointed where it needs to be. Will take some more testing with it pre-levelled to see if I need that 2nd or 3rd offset check and correction.
FWIW, I still haven't been able to do a 30s exposure. 20 is max so far. I'm in Bortle 6-7 though.
