Hi everyone,
I'm wondering if it would be possible to use my asi533 with that following configuration or the short distance from the prisme to the main camera sensor can cause focussing issue with the guide camera ( asi220mm Mini )
Asi533 with the 11mm spacer removed, but using instead the M42F/M54M adaptor threaded ring (6.5mm focal distance, and the camera directly attached to the EFW )
EFW 5x2 (2'' efw) thickness 20mm
OAG-L alone 17.5mm
M48 tilt adaptor 5mm
(6.5mm + 20mm = ** 26.5mm ** to cennect to the OAG-L )
total of 49mm minu -.6mm for the filter glass =48.4mm, so there would be 6.6mm gap to be filled toward scope side. OK for that.
On ZWO website, there is no such configuration and the closest is using a 15mm special adaptor instead of the EFW + the 11mm T2 tilt adaptor connected to the camera. (6.5mm+11mm+15mm = ** 32.5mm ** to connect to the OAG-L )
With that configuration, does that shorter distance 26.5mm from camera sensor to the edge of the OAG-L versus the 32.5mm recommended by zwo would be too short to reach out focus with my guide camera ?
