Doesn’t matter what mode I set up for -Alt or EQ. Rarely do I get more than 30% accepted. Level recalibrate gone thru all the procedures. Then in EQ I noticed after setting my initial latitude adjust 44 in my case that as unit rotates that number changes up to 4 degrees each way but when returned to home it goes back to the 44. So the question is do I have an internal sensor problem or just bad setups by myself. Any help would be appreciated. Unit is an S50 had for about 2 months in alt/az mode I use the included tripod w/leveler and in EQ I use a video head tripod with fluid head rated for 10 KG.
