Seestar's compas is very odd and unreliable thing. It shouldn't be used in PA procedure, but for some reason ZWO decided it should ))
Try this, my experience
Put ss in eq position, roughly by eye
Buttons direction up/down/left/right doesn't matter
Goto to any visible point in the sky in order for it to perform sync
Now go to the pa deviation screen
Move the numbers into green, no need to catch zeroes, just green
EXIT the pa deviation screen, this step is essential, do not press check again, just EXIT
Now enter it again. You'll see numbers different from the previous attempt. Hahahah, hello ZWO programmers))))
Repeat tuning, numbers into green. Now you could try to get numbers closer to zero.
Exit, enter, repeat.
Usually three iterations are enough.
Enjoy your eq mode! Since I discovered this method by trial and error I had no issues with tracking. Just checked 60s exposures yesterday, no problem at all.
Clear skyes!!
