gofraro
The halo you’re seeing is caused by internal reflections, which are common when imaging very bright stars. We suggest avoiding overly bright targets to reduce this effect.
As for the tilt you mentioned, it may be due to a slight unevenness of the sensor plane. To better assess this, could you please provide a single raw frame for analysis?
Please note that software updates do not affect the physical optical path or alignment. This issue is not caused by the update. It's possible that over time, slight impacts or loosening of components during use may have caused some shift in the internal alignment.
