azskyguy In macOS, you can access the files from the internal memory or any other memory you use in your ASIAir through the Finder while working with the ASIAir. If you use an external USB in the ASIAir or a microCard ( depending on the model you are using ) they will appear in the finder as network devices. Also the internal memory appears the same way. But, in my experience, what you can't do is capturing directly to the Mac, you just can drag the file from the ASIAir to the Mac using the Finder after they are capture in the ASIAir.
If you have an ASIAir cam, you can connect it to the Mac using the USB-C port in the back. The internal extorage should appear on the Desktop as an external drive, same if you plug an USB to the ASIAir cam. I haven't seen any option to add the Mac internal drives to the ASIAir cam for capturing, so I don't think is available.
