PMTeam@ZWO Using the iOS verison on my Mac.. where can I send the files?
Also, let me join in the the CAA... really needs a 'home' position, and I often find it comes close to wrapping the cords too tightly and eventually it will break the USB port. This has been solved by other rotators on the market, and needs to be solved by ZWO. Every time I go to a new target I have to go outside.
Also, as mentioned before, the WiFi is terrible on this camera. I'm about 25 feet from the telescope, which is outside. On earlier versions of the software I could see it's network easily. Now I have to go outside and put my laptop right next to the camera to see the network. Then I can go inside and usually it works for the rest of the night. But the signal is much weaker than it used to be, and since it originaly was fine, it has toi be a software issue.
