Testing the new 2.4 beta release. Equipment: ASIAIR PRO, AM5, EAF, EFW, 6200MC, 290MM Guide camera, CAA.
The software update is very unstable. The CAA routine is not working correctly, when you manually request the rotator to move the ASIAIR display updates but the rotator does not turn. It seems to work correctly when you select 360 degree mode but does not work right in the 180 degree mode. Sometimes it turns but sometimes it doesn’t but the ASIAIR display always updates and you get the message rotator complete. Three attempts in manual rotation and the ASIAIR reboots. I duplicated the reboot ten times. It always reboots on three attempts to manually move the rotator but the rotator does not move.
Tried an auto run and lost connection to the mount after 10 frames downloaded. I duplicated the mount disconnect three times. Once during an auto run I lost connection to the EAF.
Wireless communication works fine and even though I am using an ASIAIR Pro communication range was good. Never lost connection.
The USB portion of the firmware/software code is buggy.
Due to poor weather I have not been able to go on the Sky and test guiding or plate solving.
The enhanced features to the sky atlas are great.
Tried my Mele 4C using NINA and the CAA ASCOM driver works fine and the same setup, all USB cables, etc. had no issues.
ZWO software team: thank you for all the hard work, we are not there yet but moving in the right direction. Until we get this right I will use my ASIAIR plus on the 2.1 firmware and leave the CAA on the shelf.
