Under focus feature, make it easier to switch to the next camera, as the focus feature is need for both the main and guide camera, and an easy way to switch to the next camera, or between guide/main would help. As it is, you have to unload the camera from main, and select the guide camera as if its the main camera to focus it, and then put it back, which is pretty tedious.
