Hello,
Bad surprise yesterday evening : after making some images with my telescope and 533MM using ASIStudio on my Laptop, I switched to another software (Metaguide) and then came back to ASIStudio.
And then all the images were fullfilled with regularly spaced vertical lines.
I tried to check cooling, 8 or 16 bits, time duration, ROI and nearly all available parameters but result is constantly the same.
Have a look on the image joined (donut is a defocused star, used for collimation).
And images with SharpCap on Laptop are also stripped.
I also made some images with an ASIair and, good surprise, images were OK.
I also made some images with 533MM connected to my home PC (Windows 11 also) and images are OK too.
In summary : when 533MM is connected to the Laptop images are stripped. And when 533MM is connected to the tower PC with same USB cable and power supply images are OK.
Welcome to any idea to clean this up.!
Laptop is a Vivobook, Windows 11 up to date and USB cables are from ZWO. Camera drivers are last version (V3.25)
