azskyguy Hello. We have fixed the wrong meridian flip problem in 2.4.1.
I checked the logs you submitted, all of which are about meridian flip problems and status stuck at loading. Our developers have responded to all the logs you submitted.
Regarding the "No loss of exposure control" you mentioned, we suspect that the camera is offline, so the exposure time cannot be modified. This requires you to upload the log after the problem occurs so that we can further verify the guess. We have not received any feedback from other people about similar problems.
As for the plate solve failure during PA and GoTO, first of all, we recommend that you use the old parsing algorithm. Secondly, we have optimized PA in v2.4.1, and the effect of this version is consistent with v2.3.3. Thirdly, if you encounter parsing failure during the GoTo process, you can also upload the log to us to further find the cause.
