When this occurs with my S50, it helps to move the focuser manually completely in and out and back to its normal position (I can see sometimes slightly elongated stars in the upper right corner). The ASIfitsviewer has a tilt check feature, but you have to use a single fits frame to check it and not the stacked file.
But, there is a another point of failure. The Flats.
In my case, the introduction of the Flat-Shoot-function with provided factory-flats, caused the appearance of tilted halos, clearly visible on brighter stars. With IR-cut and LP-filter. And I could prove that this not happened before the update.
After some research through various sources, faulty flats can cause such aberrations, when the flats were created on a system that doesn't match the optics or, if custom flats are created once, but the optics changed in between (focuser tilt etc.).
Also, when using mosaic mode, the alignment and stacking algorithm is to consider distortions (TAN-SIP) and has to correct it accordingly. Therefore, if you see such aberrations in the sum-stack of a mosaic, try to restack it internally with the DSS or externally, using the correct algorithm.
If you see such aberrations in the single frames, the mentioned before is more likely.
