Support@Seestar I’m sorry, but I don’t understand your response.
Can you confirm if Live stacking in the Seestar app and DSS (Deep Sky Stacking) in the Seestar app are using the same logic and programming, or are they not?
I’m suspicious about this because the first time I used DSS after upgrading to V2.6 it only managed to stack 15% of my subs, where as on every single other occasion where I have used it (maybe 50 or 60 times) it stacked 100%.
If your answer is ‘they use completely different methodology to stack’ I would firstly be very surprised, but also would start looking elsewhere for the cause of the problem. If your answer is, ‘they use exactly the same methodology to stack’ then version 2.6 would appear to have introduced a bug.
