I have a frustrating problem at hand with my ASI2600mm where the camera will randomly disconnect and not communicate properly with NINA, I'm wondering if the main board is going out and needs to be replaced, but I'm having trouble replicating the problem. I bought the camera off the cloudynights classifieds in early July and did several imaging sessions with it overnight without any problems. I was originally using an AM5n mount, powered with the Pegasus 12v 10a power supply, then running a power cable from the saddle output to a Svbony power/usb box which supplied power to my mini-pc and the ASI2600mm. I have the EFW and EAF plugged into the ASI2600mm and drawing power from that. I sold the AM5n and switched to a iOptron HAE29c-EC, the AM5n saddle power output is listed at 5a by ZWO while the HAE29c saddle output is only 3a, I decided I'd run my power supply directly to the Svbony and then distribute from that to the mount, mini-PC, and camera. I also kept the usb connections from the cameras to the Svbony and then from that to the mini-PC.
Somewhere along the way I started having random disconnects between the ASI2600mm and NINA, at first I was just using one of the shorter USB3.0 ribbon cables from ZWO, it was an older cable so I quickly tossed that and hooked up a more robust new cable. Seemed to be fine for a bit, but started having more problems, eaf/efw disconnects along with the main camera. So I started to think the Svbony power box was defective and so I moved to connecting everything directly to the mini-PC utilizing the 2600mm hub to connect the EAF/EFW with the mount and guide camera connected to the PC along with the 2600mm. I also incorporated a power splitter so I could split the power from the Pegasus power supply, one cable running to the mount and one to the Mini-PC. Then I ran a power cable from the saddle output directly to the 2600mm since it only needs 3a supplied which is what the saddle outputs. I would think the Pegasus 12v 10a supply would be enough for all those things in that configuration.
There doesn't seem to be any rhyme or reason to the disconnects, last night I started the sequencer and it ran for 5 exposures, then it ran into the error and I saw it fail. I restarted the sequencer and then it ran for about 2 hours before encountering the error. From the NINA log this the sequence of errors it reports:
2025-08-17T22:40:50.4037|ERROR|ASICamera.cs|DownloadExposure|417|ASI: Camera reported unsuccessful exposure: ASI_EXP_FAILED
2025-08-17T22:40:50.4042|ERROR|ImagingVM.cs|CaptureImage|254|Camera download failed - Exposure details: Exposure time: 150, Type: LIGHT, Gain: 100, Filter: O
2025-08-17T22:40:50.4049|ERROR|SequenceItem.cs|Run|263|Category: Camera, Item: TakeExposure, ExposureTime 150, Gain 100, Offset 50, ImageType LIGHT, Binning 1x1 -
NINA.Equipment.Exceptions.CameraDownloadFailedException: Camera download failed - Exposure details: Exposure time: 150, Type: LIGHT, Gain: 100, Filter: O
at NINA.ViewModel.ImagingVM.<>cDisplayClass38_0.<<CaptureImage>b0>d.MoveNext() in C:\Projects\nina\NINA\ViewModel\ImagingVM.cs:line 236
--- End of stack trace from previous location ---
at NINA.Sequencer.SequenceItem.Imaging.TakeExposure.Execute(IProgress1 progress, CancellationToken token) in C:\Projects\nina\NINA.Sequencer\SequenceItem\Imaging\TakeExposure.cs:line 190
at NINA.Sequencer.SequenceItem.SequenceItem.Run(IProgress
1 progress, CancellationToken token) in C:\Projects\nina\NINA.Sequencer\SequenceItem\SequenceItem.cs:line 249
2025-08-17T22:40:50.4058|ERROR|SequenceItem.cs|RunErrorBehavior|195|Instruction Take Exposure failed after 1 attempt. Error behavior is set to ContinueOnError. Continuing.
Today I remote into the computer and just set the cooling on to 10C so it's running around 50% during the day, started a looping exposure in NINA, tried moving the focuser in and out while the cooler is on and looping exposures, tried changing filters, tried slewing the mount. Nothing seems to trigger the error so I'm not sure how to diagnose this. Tonight I might try hooking everything up to an ASIAir and running a quick target run with that to see if it happens with that as well, I can also try changing the cables and not utilize the USB hub on the 2600mm just to rule out that aspect. I'm wondering if the main board on the camera is going bad, but obviously there's a lot of variables happening and it's hard to isolate just a single one as the smoking gun.
Anyone have any suggestions?
