Corsair
Well I've just tested my workflow out. All went well for my use case and even better I'm really liking the new Filter that's part of the Celestial Library now. It works great.
My use case:
Unguided EAA using Live Mode for Live Stacking. I only ever use Preview, Live, Focus, and Video modes.
I don't do Meridian Flip.
I don't have an EAF (so manually focus only). I don't have an EFW (just use a ZWO UV/IR Filter which is attached to the front of the camera). I don't have a CAA.
As mentioned - I don't do guiding.
I didn't use All Sky Polar Alignment.
I didn't use "New Plate Solve".
Equipment:
Galaxy S22 Ultra Android 15, One UI version 7.0 ASIAIR App-Firmware 2.4.3 - 12.55
ASIAIR Plus 32GB
HEQ5 Pro mount connected as EQMOD Mount (EQMOD cable from mount to usb 2.0 port on ASIAIR Plus) with its own power supply.
C8 SCT with f/6.3 Reducer and dew shield
ASI294MC Pro camera cooled to 0°C connected to usb 3.0 port on ASIAIR and powered from the ASIAIR.
After setting up during the late afternoon/early evening first thing I do in Preview Mode is a plate solve and I check for expected behaviour when pointing at the SCP (i.e. mount in Home position) then when pointing greater than 5° away from the SCP.
Mount Settings > Go Home to check Home position set correctly.  Tap on Sync Mount.
Mount in Home position, Preview Mode, 2s exposure, Focus is good so Plate Solve succeded nice and fast, tapped on Sync and received expected error message about being too close to the SCP.
Manually slewed away from the SCP using the on screen mount controls. Preview Mode, 2s Exposure, Focus good, Plate Solve succeed nice and fast, tapped on Sync and sync succeeded.
Now I did the Polar Alignment. This went smoothly. I don't use auto refresh but manually refresh. So whenever I make a chance I wait for 5 seconds for the mount to settle then tap refresh. PA Total Error of around 00°00'20". Happy with that.
Then went back into Preview Mode. Then went to Mount Settings > Home. Then after the mount returned to the Home position went to Mount Settings > Sync Mount.
Interestingly, I decided to run the above Polar Alignment routine again, and when I did I didn't notice any significant change in the Total Error. It still stayed around 00°00'20". So there's that.
With Mount back in Home position, I opened the Celestial Library, went to Name Stars, and found a bright star in order to manually refine focus with a bahtinov mask. Tapped on Centre. Then when the ASIAIR took me to the star map I tapped on the option to Go To the target. ASIAIR slewed to the star, centered after about two goes, plate solved, succeeded. Star was centered nicely when checked in Preview Mode.
Went into Focus Mode. Began the process. Put in bahtinov mask. Dragged green box over star and tapped Zoom. Zoomed into star perfectly so I could manually adjust focus. Once done took off bahtinov mask, left the Zoom mode, stopped Focus Mode routine.
Mount Settings > Go Home. Once back in Home position, Mount Settings > Sync Mount.
I tested browsing to a target (NGC 300). Once again - the Filter worked great in the Celestial library. Centred on target. Then tapped the optiion to Go To the target. Again, after a couple of goes, ASIAIR centered and plate solved successfully.
Took a 30 second exposure in Preview Mode to check all was well. Worked great.
Went into Live Mode. Selected 30 second exposure. Bin 1. Time spent capturing set  to 20 minutes. Select Master Dark and Bias (yes, I know, don't need bias frames for my camera but I thought I'd do it anyway as a test). Didn't do Flat frames as I didn't have a lot of time and just wanted to get the test done. Anyway, I've tested out doing all calibration frames previously with the same setup and it's worked great (did it indoors due to the weather).
Ran the Live Stacking in Live Mode for 20 minutes . Target captured nicely.
Then went to Mount Settings > Go Home. Mount returned to Home position.
Turned everything off and packed up for the night (I don't have a permanent setup and can't unfortunately).
Conclusion:
ASIAIR App-Firmware 2.4.3-12.55 worked as expected for my workflow. No issues. I'm happy with it.
FYI: I did screen recordings through the whole thing above and will put together a video that I'll share when I can.
