I saw the photo, but it might not clearly show the issue. I think my image didn’t come out well.
The ZWO T2 Tilter never allows perfect sensor alignment, which makes it nearly impossible to use the ASI 533 MM/MC Pro properly.
I’m not sure how to solve this, because the 533 can’t be directly connected to the EFW 5x2 in a way that ensures proper sensor centering.
The only option is to attach the T2 Tilter perfectly to the EFW 5x2, but even then, the sensor alignment isn’t accurate.
See the attached photo below:
The connection between the T2 Tilter and the EFW 5x2 works mechanically without issues, but as you can see in the image, the camera sensor is not perfectly aligned. That’s the real problem.
