I would like to use a 3D printer to print some attachments for my Seestar S50. Is it possible to obtain 3D data for the telescope housing? This would save me from having to recreate all the data based on the design sketch in the manual.
https://www.zwoastro.com/product/seestar-s50/
Yes, I know this drawing from the manual. I was thinking of real 3D data, which would make things much easier.
Brille We apologize, but we do not possess the relevant 3D real-world data.
Brille I do have an S50 shell (for the main body, not the arm) in Fusion 360 if you are interested.
starnet59 This would be great. I do not own Fusion360, so any universal interchange file format would be fine (like STL or OBJ). I am not sure, if its possible to send private messages in this forum.
Brille You can contact me directly at catalin59 at yahoo dot com
Brille Also, there is nothing to own, Fusion 360 is free for personal use. I can provide an STL (3MF actually but exporting STL or OBJ should be possible, I need to check) but you will need to modify this shell design and add your own stuff anyway.
