- Does not work when plugged directly into Pi5
- HID driver is not loaded
- bInterfaceClass is 3
`lsusb -v -d 03c3:1f10
Bus 001 Device 002: ID 03c3:1f10 ZWO EFF
Device Descriptor:
bLength 18
bDescriptorType 1
bcdUSB 1.10
bDeviceClass 0
bDeviceSubClass 0
bDeviceProtocol 0
bMaxPacketSize0 16
idVendor 0x03c3 ZWO
idProduct 0x1f10 EFF
bcdDevice 0.00
iManufacturer 1 ZW0
iProduct 2 ZWO EFF
iSerial 0
bNumConfigurations 1
Configuration Descriptor:
bLength 9
bDescriptorType 2
wTotalLength 0x0029
bNumInterfaces 1
bConfigurationValue 1
iConfiguration 0
bmAttributes 0x80
(Bus Powered)
MaxPower 64mA
Interface Descriptor:
bLength 9
bDescriptorType 4
bInterfaceNumber 0
bAlternateSetting 0
bNumEndpoints 2
bInterfaceClass 3 Human Interface Device
bInterfaceSubClass 0
bInterfaceProtocol 0
iInterface 0
Warning: Descriptor too short
HID Device Descriptor:
bLength 9
bDescriptorType 33
bcdHID 1.01
bCountryCode 0 Not supported
bNumDescriptors 2
bDescriptorType 34 Report
wDescriptorLength 68
bDescriptorType 0 (null)
wDescriptorLength 0
Report Descriptor: (length is 68)
Item(Global): Usage Page, data= [ 0x00 0xff ] 65280
(null)
Item(Local ): Usage, data= [ 0x01 ] 1
(null)
Item(Main ): Collection, data= [ 0x01 ] 1
Application
Item(Global): Report ID, data= [ 0x01 ] 1
Item(Global): Report Count, data= [ 0x0f ] 15
Item(Global): Report Size, data= [ 0x08 ] 8
Item(Global): Logical Maximum, data= [ 0xff 0x00 ] 255
Item(Global): Logical Minimum, data= [ 0x00 ] 0
(null)
Item(Main ): Input, data= [ 0x02 ] 2
Data Variable Absolute No_Wrap Linear
Preferred_State No_Null_Position Non_Volatile Bitfield
Item(Global): Report ID, data= [ 0x02 ] 2
(null)
Item(Global): Report ID, data= [ 0x03 ] 3
(null)
Item(Main ): Output, data= [ 0x02 ] 2
Item(Global): Report ID, data= [ 0x04 ] 4
(null)
Item(Main ): End Collection, data=none
Endpoint Descriptor:
bLength 7
bDescriptorType 5
bEndpointAddress 0x81 EP 1 IN
bmAttributes 3
Transfer Type Interrupt
Synch Type None
Usage Type Data
wMaxPacketSize 0x0010 1x 16 bytes
bInterval 10
bLength 7
bDescriptorType 5
bEndpointAddress 0x01 EP 1 OUT
bmAttributes 3
Synch Type None
Usage Type Data
bInterval 10
Device Status: 0x0000
(Bus Powered)
It looks to be related to the latest OS update. I have an SSD card with an older OS on it, and it works.
