Since last week (last firmware update), I've noticed a pinkish tint across the entire image area with increasing stacking time. The longer the stacking is, the more intense it becomes. Barely visible up to 5 minutes, but significant after 30 minutes.
It occurs both with the LP filter enabled and with subjects without the LP filter enabled, but subjectively it's somewhat less pronounced in these cases.
I'm using the S50 in normal mode, without any additional filters or other specifications. Everything has worked perfectly so far.
Attached are a few screenshots to illustrate the problem. I can't find anything about it online and would appreciate any help. I sincerely hope it's not a filter defect, but some kind of software issue.
Thanks for any advice.
