Tech@ZWO
Thank you for the response.
Prior to setting up the S50 was inside the house with the AC set at 75 F degrees. Once outside I it took about 15 minutes to setup the S50 and to level and polar align the scope. The outside temperature was around 71 F degrees. There wasn't any heat generating objects in the vicinity. I am running V2.6.1 on my Samsung Galaxy S25 and I don't see the "Report Bug & Log" option on phone. But I do see it on my Samsung Galaxy Tab S6 tablet running the Seestar V2.6.0, but I can't submit the log since it doesn't have cellular feature. Is there a log file I can access via usb connect so that I can send to you? This was the third or fourth time I have used the S50 and the first time it had this warning.
