Sorry, I may not have explained myself clearly. When photographing comets, you can use the equatorial mount mode, and then set the single exposure time to 10 seconds. Generally, the shorter the exposure time, the shorter the comet's tail will be; conversely, the longer the exposure time, the longer the comet's tail will appear. You can enable single-frame saving (you can perform stacking processing yourself in post-production).
