I operate an S30 from a remote observatory in EQ mode. The past few nights I have had the following problem:
1.I open the arm and send it to a bright star .... it doesn't find this.
2,I look on my pier cam and it is sat with the arm open looking West at the height of my neighbours Seestar, claiming it has found the star. The angle is that of the initial Open Arm position.
3.I use the joystick and move it to a star field, and then start the autofocus and warm up going.
4.Once this is done I check where it is and if it looks like the Skyatlas has identified where it is I stop the stack and hit sync on the Skyatlas.
5.Then I have to find a nearby bright star on the Sky Atlas and hit goto - the Seestar then does a complete rotation to find the star (the star I find it to go to is always very close).
6.Seestar finds this and then does a correct find alignment and starts stacking. I stop the stack and once more hit sync in Skyatlas as I now have a definitive proof that the Seestar knows where it is.
7.Then I can go to my intended target for the night. When I find this target tracking and dropped frames are very minimal. Everything works as intended.
Points to note:
Seestar is turned on and off via a Switchbot - Seestar is not on all the time and users at the observatory power their seestars on and off.
The Seestar is correctly EQ aligned on a permanent basis on a WIllams Optic Wedge (very stable)
The Location in the app is correct for the location of the remote observatory - The App runs locally next to the Seestar on an M series Mac that can run the Seestar App. I always ensure that I have reloaded the location in the app so it will refresh in the app and to the Seestar.
The Seestar is fully charged and remains on charge at all times. The power is controlled via a wifi controlled power strip.
At times when the Seestar gets confused like this it can "forget" it is connected to a power source and can start to lose power - cycling the power strip remedies this, but can be a symptom that helps to determine if this is an error.
Restarting the Seestar does not fix this issue.
Once a successful target is found and stacking starts the issue is fixed and power will return to normal expectations.
Please advise if this is a known bug or a newly found bug. I have seen reports of users with their Seestar with them in person experiencing the same problem. Lastly, I have an S30 and S50 at home and this S30 at the remote observatory, I have been using Seestars for over a year and I do not believe this is a user error.
Thanks for your time and please advise if you would like to me to test anything on my end to get a resolution to this.
