Things like this make for lots of frustration. Trying to switch to 2.4ghz and it thinks it is already in 2.4ghz. Actually, it was but the logic seems fouled up. Not the first time. Switching from 2.4ghz to 5ghz and vice-versa ALWAYS is a PAIN. Back and forth. Several attempts and it finally decides to work.
You told me a while back to NOT use 2.4ghz due to negative bluetooth interaction. Well, it seems that is not an accurate statement.
on-screen instructions are not accurate and don't function as expected.
